Hab ich beim Schnüffeln gefunden.
Kommt das auch oder nur ein Prototyp?
Auch verkauft Midland jetzt das Wouxun oder Albrecht.
Bezeichnung CT 790
Midland G14
Multifunctional PMR446 transceiver
Midland G14 is a PMR446 professional transceiver that
combines the latest technology in radio communication
along with a sturdy mechanical frame. It’s the best
and effective solution for the professionals who need to stay
in touch with colleagues in construction sites, buildings,
hotels, trade fairs or shows.
Midland G14 is equipped with a Li-Ion battery pack to
guarantee maximum performance and maximum life span.
All the functions are shown on the wide LCD display and
easily settable through the selection knob.
This transceiver is also equipped with a Scrambler function
that is designed to protect communications.
This feature prevents parties from other networks from
hearing and understanding voice communications.
It is possible to extend the flexibility and the features of
your radio through the specific PRG G14 programming
software (optional).
Accessories jack: KENWOOD 2 pin
COLOUR: black
SINGLE PACKAGE Code: C901
1 G14 transceiver
1 belt clip
1 wall adapter
1 1200mAhLi-Ion rechargeable battery pack
1 desktop charger
1 user manual
MAIN CHARACTERISTICS
• PMR446 Transceiver
• Output power: 500mW
• Channel spacing: 12.5KHz
• Channels: 8 PMR446 channels+ 91 pre-set channels
• Backlit LCD display adjustable in 3 different colours.
• 50 CTCSS and 105 DCS selectable codes
• Keypad lock function
• 2 SCAN modes: all channels SCAN and PRIORITY CHANNEL SCAN
• Emergency alarm
• Built-in VOX function (vocal-activated conversations)
• Scrambler function
• Busy Lock Out function
• Time-out Timer function
• Auto power save: for maximum battery life
• High/low selectable output power
• Low battery level indicator
• External jack for microphone or speaker (2 pin KENWOOD)
With the PRG G14 programming software (Code: C902) it is possible to:
- modify the output power
- Customize channels and frequencies
- Enable/disable specific functions
Bezeichnung CT 790
Midland G14
COLOUR: black
1 G14 transceiver
1 belt clip
1 wall adapter
1 desktop charger
1 user manual
• Emergency alarm
